Is there a better option for my Valve springs?
Old Nov 9, 2007 | 10:16 PM
Tricked-Out-Toy's Avatar
Right now Im running comp 977's with around .601 lift on my LE3 heads. they have been on the car for a while and work fine but have to be near the end of there life.. I dont think theres a time that the car goes out and doesnt see 6700 rpms.
So my question is, should I just replace the springs with another set of 977's or is there something better out there that would reduce the valve train weight?
On a side note I plan on running a smaller cam with the turbo setup im building (winter project), something in the 580 lift and 220 duration area. would something that works for the .600 lift be the same for the smaller cam?
Old Nov 10, 2007 | 07:40 AM
rskrause's Avatar
Moderator
If they work fine, what do you hope to gain? Why do you say they are at the end of their life? Anyway, if they work well and you want new springs I'd say get the same thing.
Rich
Old Nov 10, 2007 | 10:33 AM
well there almost 4 years old, and have taken a beating. springs dont last forever and as preventative maintenance I figured I would replace them before they broke.... Im hoping to gain a lighter valve train....
Old Nov 10, 2007 | 12:49 PM
T/A KID's Avatar
PAC 1518 is a .650 lift beehive that will most likely last the life of your engine.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
