Is there any better timing chain you can use with a 94 LT1
Old Jan 3, 2004 | 03:29 AM
  #16
bunker's Avatar
Cloyes always made one for the LT1 I belive unvented, it retails for about $600 aswell. Not worth it bro, just get a Lunati if you do n't want to upgrade, any aftermarket chain is good IMO, aren't GM ones Cloyes anyways? I thought Cloyes makes GM chains no?
Matt.
Old Jan 3, 2004 | 09:40 AM
  #17
Josh-'04 GTO's Avatar
The Lunati looks like a great buy at $108. No doubt it is better and stronger than the stock setup.
Old Jan 3, 2004 | 09:58 AM
  #18
93Z286Speed's Avatar
hate to have an awnser repeated but
Will the lunati work with my 93 Lt1 with stock waterpump
Old Jan 3, 2004 | 10:28 AM
  #19
Mtrhds94Z's Avatar
It supposedly fits 93-4 early unvented optis, so yes..
I haven't seen one yet, the pic posted above doesn't look 'right', but Shawn W says above that he has one, so I am inclined to believe that yes, it fits...
Let's hope so we need other options to the opti 'upgrade'
Old Jan 3, 2004 | 02:01 PM
  #20
v7guy's Avatar
it just seems rediculous that we would have to change to the newer opti, maybe if the opti went out it would be a good time to do it, but I just replaced it a couple years ago so it seems quite rediculous, I can't believe there aren't more option out, it blows my mind, the market is there, I don't understand grrrrr
Old Jan 3, 2004 | 02:38 PM
  #21
blk95z28conv's Avatar
94 timing chain
I am putting a 94 lt1 block in my 95 z28 the 94 block has no timing chain at the present HELP what do I do
Old Jan 3, 2004 | 02:46 PM
  #22
v7guy's Avatar
well if you don't have a timing cover or an opti go ahead and put on a vented opti and get the timing cover for it, other wise you can just put one from a 94 or 93 on it, you'll have to cut the dowel pin or push it back through a little bit so it'll fit if it has the 95 cam in it, what you do is going to laregly depend on what you already have
putting a vented opti with the timing cover for it on that motor will open up your option alot as to timing chains though
Old Jan 3, 2004 | 03:04 PM
  #23
brain's Avatar
So to recap, the consensus right now is this -
Lunati Chain
nonvented opti
stock waterpump
If thats the case, then
Lunati Chain
nonvented opti
electric waterpump
should be no problem then right?
These cars are so wierd. You can't change one thing without changing 20 others.
Old Jan 3, 2004 | 04:15 PM
  #24
Mtrhds94Z's Avatar
Right..
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
