thanks for your help one more question
Old Jan 26, 2005 | 04:10 PM
Irocdriver89's Avatar
Angry thanks for your help one more question
when i'm driving the car tends to stay real cool but when i slow down the car heats up not real fast but fast enough for me to notice then when i take off the car cools back down to regular temp or when im onj the freeway it real be real cool then when i get off the temp will go all the way over just before the red line but never sits long enough to get hot
Old Jan 26, 2005 | 05:00 PM
redcamaroz28's Avatar
Re: thanks for your help one more question
Try bleeding the system for air pockets. Also you can lower your fan kick on temps through programing or install a manual fan switch.
Old Jan 26, 2005 | 05:20 PM
redemn93's Avatar
make sure your fans are working properly
Old Jan 26, 2005 | 05:45 PM
Punkillr's Avatar
an easy fix might be just changing out the thermostat. if you have a 160 you might want a 180, or try a new 180. there cheap and fast to put in
Old Jan 26, 2005 | 11:31 PM
Angry Re: thanks for your help one more question
ok after running the car real hard a couple of times up and down the block the temp went to 210 and stayed there the fans were not on and they don;t seem like there going to come on either were is the fuse on a firebird for the fans i looked in the fuse panel in the car and i lost the cap from under the hood but i checked all thoses fuses and they seem to be good what else could it be.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
