testing the cooling fans(help)
Old Feb 6, 2004 | 01:20 PM
airborneluva's Avatar
Question testing the cooling fans(help)
Hey guys, anyway for me to check if my fans are coming on? I don't have any electrical equipment or circuit testers or whatever. Can i just start the car and turn the AC on? Turn the AC w/o the car actually running?
Thanks again
josh
Old Feb 6, 2004 | 01:56 PM
lifbcracker's Avatar
hmm
You could pull the fans out and test each one individually, or wait till your car heats up to 210. If your unsure if power is getting to them, then get one of those peirce testers with the light on the end that turns on if theres current (I cant think of the figgin name at the moment). But other then that- check to see if you grounds are connected. hope that helped at all
Old Feb 6, 2004 | 02:26 PM
Probably more than you want to know about the cooling system and fans here.
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
