Temperature Sensor help
http://shbox.com/1/temp_sensor2.jpg
i have no temperature sensor in the head but there is no wire to plug in and i cant find a lose wire anywhere.
where does this wire start????
how much do you think a place would charge to put in the complete line.
Always a lot harder to answer your question when you don't include basic info about your car... like the year. May explain why you got no responses, and resorted to pushing the post to the top in less than 24-hours. Please read the "sticky" at the top of the forum regarding abuse of TTT.
Maybe including something about your car in the "signature" field would make a bit more sense than your offensive quote.
If your wiring harness is similar to Shoebox's 95, you can look in the lower right corner of this photo, and see where in the harness the wire for the head temp sensor is routed.
http://shbox.com/1/harness.htm
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 5, 2015 08:35 AM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
