temperature problem
Old Mar 28, 2007 | 08:20 PM
  #16
OBE1 95Z28's Avatar
Sounds like you may have a couple of issues. Bleeding the air out of the coolant system as stated above, and a bad wire/connection to your temp sensor. The temp sensor is located in the driver's side head between spark plugs 1 and 3. If the wire or connection to the sensor is bad, your temp gauge will jump around.
Old Mar 28, 2007 | 08:57 PM
  #17
needsize's Avatar
the sensor thing sounds right, as no way it should jump around that fast, I'll check that out tomorrow....
warmeck
Apr 27, 2015 04:34 PM
Biggiebound
Apr 21, 2015 11:28 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
