temp gauge sensor doesnt fit
Old Dec 7, 2006 | 01:17 PM
94_camm's Avatar
I have a set of trickflow heads .i was goin to put the sensor in but it is to small for the hole.is thier like an adaptor i need?
Old Dec 7, 2006 | 02:59 PM
You should easily be able to find an adapter fitting.
Old Dec 7, 2006 | 03:09 PM
Mikek340's Avatar
Yea just go to your local hardware store to find the adapter. I have the same heads and thats what i had to do.
Old Dec 7, 2006 | 03:38 PM
94_camm's Avatar
is thier a part number or size anyone has?
Old Dec 15, 2006 | 09:41 PM
ponyackn's Avatar
Bump for ya, I'm just realizing the same thing.
Old Dec 16, 2006 | 08:21 AM
Dave89IROC's Avatar
size you probably need is 3/8" NPT female to 1/2" NPT male, but, since I don't have your sender here, I'm not sure
Old Dec 17, 2006 | 06:24 PM
ponyslayer02's Avatar
any news yet i am having the same problem
Old Dec 17, 2006 | 11:30 PM
Measure the threads. Get the correct adapter bushing. I wouldn't be surprised if AutoMeter had them in the catalog.
Old Dec 18, 2006 | 05:48 AM
we are both trying but they are not NPT threads i believe they are machine thread. sucks
Old Dec 18, 2006 | 06:07 PM
ponyackn's Avatar
Do you remember the thread size?
Old Dec 18, 2006 | 07:15 PM
Mkos1980's Avatar
I just used what the other guy used. Basic pipe fitting with 3/8 female to 1/2 male. About 50 cents at any hardware store.
Old Dec 18, 2006 | 10:02 PM
SnakeOiler's Avatar
As much money as they charge for the heads, you think they'd tap the right size hole!
Old Dec 19, 2006 | 07:33 AM
ta4me's Avatar
While you are there youu need to get plugs for the water jackets in the front of the heads, these don't come with them either. I could not get mine out of my stock heads. The directions tell you that you need to buy an adapter.
Also, You can not use the stock intake bolts on the outer corners of the intake. The holes are not tapped deep enough, you'll strip them out............. Ask me how I know!!
Old Dec 20, 2006 | 12:36 AM
TransAm396's Avatar
what do you use for bolts then?
Old Dec 20, 2006 | 03:52 AM
SS RRR's Avatar
You can still use them, but if the bolt holes are too shallow you just shim the bolts. that's uber gay if that's the case.
