the temp on the fan
Old Oct 8, 2009 | 12:06 AM
94Z28LS1toLT1's Avatar
the temp on the fan
is the fan supposed to kicked on at 3/4 of the temp gauge i have a 94 Z28 with 96 LT1 engine
Old Oct 8, 2009 | 05:23 AM
The middle of your gauge is ~212*F. The first fan (or low speed in "late" 94's and up) turns on at 226*F, and the second fan (or high speed) turns on at 235*F. The gauge reads the temperature sensor in the driver's side head. The PCM uses the temperature sensor in the water pump housing to control the fans.
Old Oct 11, 2009 | 11:34 PM
the two fans/is my car running hot?
is car running hot?, my two fans kick on at 3/4 of the temp gauge and it goes like almost to the middle when it cools down and when i turn the car off i dont hear any boiling so are my fans good
Old Oct 13, 2009 | 05:32 AM
The dash temp gauge and the PCM feed come from two different temperature sensors. Its possible that one of the sensors is not providing the correct readings. Put a scanner on the PCM and see what temps the fans are going on and off at, according to the PCM temp sensor.
The center of the gauge is about 210*F. With the stock thermostat and stock fan programming, its normal for the engine to run with the needle in the center of the guage.
Old Oct 13, 2009 | 08:18 AM
rngilliland's Avatar
That is the way my car has worked since new. Without the A/C on the fans cycle on and off and the temp gauge swings up and down about like you have described. With the A/C on the temp stays steady since the fans run all the time. On the highway or with the A/C on the temp runs just above the 1/4 mark.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Zuvell
May 15, 2015 08:18 PM
Biggiebound
Apr 23, 2015 08:50 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
