temp is 250?? is that too high
Old Aug 21, 2010 | 02:30 PM
javi805's Avatar
i judt did a radiator flush i used the dex-cool 50/50 for my 97 camaro lt1. i was dring it around and the temp was at 250 is that too high or should it be lower?? need help
Old Aug 21, 2010 | 02:48 PM
GreenDemon's Avatar
250 is about as high as you can get w/out boiling over.
Let the engine cool down for a while, then add coolant, make sure the radiator and reservoir are both full.
Then with the engine running and warming up, open the bleeder screw until coolant comes out- sometimes it will bubble out for a while, just let it come out until there's no air. LT1's can sometimes be tricky to get the air out of. 225-230 is usually about the hottest it should get if it's just sitting and cycling the fans.
BTW don't add coolant to an overheating engine- bad things can happen...
Old Aug 21, 2010 | 02:58 PM
javi805's Avatar
o ill try it right now the engine is cooling down thank dude
Old Aug 21, 2010 | 03:03 PM
RamAir95TA's Avatar
You need to make sure both bleeders are open when you're filling the radiator with coolant, otherwise you'll get tons of air.
Old Aug 21, 2010 | 03:05 PM
javi805's Avatar
by bleeders what u mean?? the screw on botton of radiator?
Old Aug 21, 2010 | 03:13 PM
moparman's Avatar
The bleeder screws are located up by the water pump. Look at the hoses leading to the water pump, you'll see two screws. Be careful you don't drop them if you take them all of the way out.
Old Aug 21, 2010 | 03:48 PM
If you don't know what bleeders are, you surely have air pockets in your system.
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Aug 22, 2010 | 02:29 PM
94Z28LS1toLT1's Avatar
that happened to me before lol
Old Aug 22, 2010 | 03:35 PM
javi805's Avatar
i know what they are now i checked them now the temp is back to normal thanks for the advice
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
