Tell me what's going on past 6k (dyno graph included)
Old Feb 5, 2007 | 12:12 AM
  #31
SS RRR's Avatar
Originally Posted by Sweetred95ta
I built the motor to hand rpm like that. Use the heads and cam that I have and only rev it to 6k and you're not going to see the full potential of the combination.
I really appreciate all the help guys. How do I check my installed valve height? I'll be doing this spring swap after it starts to get a little warmer, so the results may take a little while.
You need yourself one of these:
http://store.summitracing.com/partde...5&autoview=sku
Very easy to do. Just a PITA.
Old Feb 5, 2007 | 06:12 PM
  #32
ayers1967's Avatar
Well all of your guys stock main caps must be stronger than any ones i have ever had. mine always tryed to move around when shifting at 6500.After dissassembly my block looked like you beat it with a hummer under the main cap.Now if you run splayed caps it will last.
Old Feb 5, 2007 | 06:40 PM
  #33
Sweetred95ta's Avatar
It helps to use ARP fasteners.
Old Feb 5, 2007 | 06:53 PM
  #34
mdacton's Avatar
I have the stock main caps...stock rod bolts... stock pistons....its all STOCK, the LT1 botton end will last you if it is put together right
Old Feb 9, 2007 | 05:33 PM
  #35
ayers1967's Avatar
Cool
Originally Posted by speed_demon24
I raced karts in the briggs class, it must have been a long time ago if you were only revin to 6200, I was turning my motors 7,000. And they actually set those motors up to float the valves since they limit the lift so low.
Ok so looking at your times posted you didnt gain any thing shifting at 6300 over shifting at 5800 . looks to me like your motor was of of its power range at 6300. Oh it may have made a little more horsepower. but that onlys shows up in mph. your tork was done at 5800 and thats what you can feel.and mybe you should go back to racing briggs engines.
Old Feb 9, 2007 | 05:38 PM
  #36
speed_demon24's Avatar
I wen't slower because of the worse 60'. Maybe you should go back to magazine racing since you obviously don't know anything about real would drag racing. A gain of 3mph shows the cars in its powerband MORE not less.
Old Feb 9, 2007 | 05:48 PM
  #37
ayers1967's Avatar
Put it on a dyno and then you will understand a little more.
Old Feb 9, 2007 | 07:19 PM
  #38
Z-RATED94's Avatar
speed, it was along time ago. But like I said, this was a stock class motor running on gas, geared for a 1 and 3/4 mile track.
sweet, I'm almost positive you'll find your problem as was mentioned by most, once you match the right springs to that cam. I know I did.
ayers, don't know what your problem is, but you need to lighten up a little.
Old Feb 10, 2007 | 12:36 PM
  #39
ayers1967's Avatar
I need to lighten up! you got on here and bashed me so I throw a little of tit back and can"t take it. its like dealing with kids.
Old Feb 10, 2007 | 12:40 PM
  #40
mdacton's Avatar
nobody bashed you, you don't seem to understand there is alot more to racing than a dyno. calm down
Old Feb 10, 2007 | 12:50 PM
  #41
Sorry, I didn't realize you were a dyno racer and not a magazine racer. And I've had my car on the dyno on over 10 seperate occasions so I think I know a little about hp vs torque.
Old Feb 10, 2007 | 07:46 PM
  #42
ayers1967's Avatar
If you are a so call real world drag racer than why do you go to the track with street tires on your car ? Start saving your paper route money so you can buy some slicks.And this is the last time I will post back on your comments. So if it makes you feel like a big man you can have the last word I"m done with you.
Old Feb 10, 2007 | 08:04 PM
  #43
SStrokerAce's Avatar
Dam dude, do you want help or to argue with these guys?
Old Feb 11, 2007 | 10:04 AM
  #44
dragonz28's Avatar
Why the hell would you dyno a car over 10 times? That's a lot of wasted $$$ that could be used to buy other mods.
Old Feb 11, 2007 | 02:51 PM
  #45
bdc95ta's Avatar
lot of reasons for each mod he could of thrown it on the dyno afterwords to see what's up....or perhaps tunning, probably both.
-b
