Technical? Will A/F change with 1.6 RR's?
Old Dec 20, 2004 | 05:11 PM
stereomandan's Avatar
Question Technical? Will A/F change with 1.6 RR's?
Last time at the dyno, I was running rich, 12.5-12.1 from 4500 rpm+
I'm adding 1.6 RR's this spring and was wondering if it will change my A/F ratio at WOT.
I was thinking that since they help the engine breath, that they might raise the A/F ratio and get me close to 13.1 Or will the PCM compensate for the extra breathing and keep my current A/F at WOT.
Any thoughts on this?
Thanks,
Dan
Old Dec 21, 2004 | 12:08 AM
Re: Technical? Will A/F change with 1.6 RR's?
The PCM reads the air flow via the MAF sensor, and adds the required fuel. If your 1.6 RR's increased air flow, the PCM would see it an add the extra fuel, using the same "target" A/F ratio that it was programmed for. Shouldn't change what you see on the dyno with a wideband.
Old Dec 21, 2004 | 01:38 PM
Thanks Fred. I was hoping that you would chime in. Looks like I'll make another dyno run this spring with the new valvetrain(assuming that there is another dyno day)
I'll see where my A/F is, and send the PCM to Ion to get tweaked again.
Dan
BLK1997Z28
May 7, 2015 03:01 PM
alliance12364
Mar 6, 2015 04:39 PM
SABLT194
Aug 3, 2002 09:33 AM
