Technical cam question
Old Feb 24, 2004 | 07:57 AM
rkussy's Avatar
I bought a 230/236 cc for a 92 vette engine with the short dowl pin and the small hole on the end of the cam for the non vented opti. I have now decided to go with a vented opti and the ED timing set. Does anyone know the dimensions that I need to open the front hole to. Such as how deep should it be, what circumference and is there any taper.
Old Feb 24, 2004 | 08:36 AM
This info came off the board some time ago:
The center hole in late cams is .500X1.0625.
That looks pretty accurate from measurements I have done, myself.
Old Feb 24, 2004 | 01:19 PM
rkussy's Avatar
Thanks shoebox I had just called comp and they gave me the same info. Your site is great lots of good info.
Old Feb 24, 2004 | 09:38 PM
rkussy's Avatar
Also comp said there is a 60 degree chamfer on the outer edge of the hole
Old Feb 24, 2004 | 10:04 PM
There is a chamfer. 60° sounds reasonable.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
