Tearing down the top end
Old Apr 20, 2004 | 04:43 PM
30thCamaroZ's Avatar
So. I got the intake all unbolted but it seems to be caught up. I know it's that damn hose on the back but I can't seem to get it off. Also when I pull the heads. Do I have to pull the rockers? Or just the bolts in b/t them and then along the bottom of the head? How do you take the fuel rail completely off? It's off to the side but not out of the engine bay. This is my first time and I was moving along pretty good but can't get that intake out. Any help would be apprecieated. Thanks, Jarred
Old Apr 20, 2004 | 04:47 PM
97WS6SCharged's Avatar
You don't have to remove the rockers, but it's a good idea to do so. It makes it easier to get to all the head bolts, and you really should remove the pushrods so you don't bend them when you remove the heads. To completely remove the fuel rails, you will need a fuel line disconnect tool. Which hose are you saying the intake manifold is caught on?
Old Apr 20, 2004 | 04:54 PM
There is some flex hose it's kinda shiny on the passenger side. If I can figure out how to get that off I can prolly get the intake off.
Old Apr 20, 2004 | 05:01 PM
You mean the EGR hose?
http://shbox.com/1/oil_pressure_sensor.jpg
Old Apr 20, 2004 | 05:02 PM
ibanez6rg's Avatar
That's the EGR tube. Two bolts hold in on the back of the manifold, not hard at all to get to.
Old Apr 20, 2004 | 05:03 PM
Yeah I saw the two bolts already just couldn't get a socket on them. Anyone know the size?
I will go do it right now if you know the size.
Old Apr 20, 2004 | 05:08 PM
They should be 1/2"
Old Apr 20, 2004 | 05:14 PM
Robbie's Avatar
1/2in or 13mm.
Old Apr 20, 2004 | 06:17 PM
Originally posted by Robbie
1/2in or 13mm.
Well, which is it?
1/2"
Old Apr 20, 2004 | 07:00 PM
95RagtopTA's Avatar
After you get the EGR hose off, the intake will still be stuck on there good from the RTV. Here's a tip: if you haven't already, take the throttle body off (be careful not to rip the gasket), then screw in the 2 upper TB bolts halfway. Stick a crowbar between them and slowly pull up. This will help break the seal without damaging your intake.
Old Apr 20, 2004 | 07:12 PM
bdc95ta's Avatar
wow shoebox that's a great picture!
Old Apr 21, 2004 | 12:36 PM
I had already broke the intake lose. I just put my hand in the intake and pulled my *** off. Those bolts weren't hard and intake came right off. Thanks for the help. I knew that those were there just couldn't seem to get a socket on them but I got it.
Old Apr 21, 2004 | 05:36 PM
Dave88LX's Avatar
If you want just loosen the rocker bolts to turn them sideways and pull the pushrods out. Don't need to remove the rockers all the way to get the heads off.
Victor Lamb
Aug 26, 2017 02:52 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
