TB Cleaning...
Old Dec 24, 2003 | 07:10 AM
Jag's Avatar
Jag
TB Cleaning...
quick question...
When I take off the TB to clean it, I assume there is a gasket. Is it reusable?
Thanks!
Old Dec 24, 2003 | 07:58 AM
gamecockfan04's Avatar
Yes. The gasket that fits in between the TB and the Intake is reusable, however there is another gasket on the TB plate(top part on the TB with 6 torq screws) which is very difficult to reuse because it is so flemzy. I reused mine after I cleaned the TB, but replaced it soon after.
Old Dec 24, 2003 | 07:59 AM
95_LT1_6SPD's Avatar
there is a nice thick gasket between the tb and the intake. It will be reusable unless it somehow gets ripped or something while cleaning.
Old Dec 24, 2003 | 08:08 AM
Jag's Avatar
Jag
Thanks guys...I guess I'm goint to take the plunge.
Old Dec 24, 2003 | 08:14 AM
Go to your local GM dealership and get the TB gasket set, it comes with both gaskets and it's only about $10.
Old Dec 24, 2003 | 08:25 AM
Jag's Avatar
Jag
Thanks, I'll get the set for just in case...
Old Dec 27, 2003 | 01:30 AM
OBE1 95Z28's Avatar
After cleaning my TB I had a problem with the idle hanging at a high RPM. I ended up dabbing a little oil on the butterfly rod (where it enters the housing) and the hanging RPM was solved. Also gently clean the IAC valve...it's fragile.
Old Dec 27, 2003 | 02:05 AM
Wild1's Avatar
Are you just trying to clean the blades or soak the whole thing. You can dust the carbon off the blades with a TB Cleaner or Carb Cleaner (depending if there is a coating) without removing the whole TB.
Steve in Seattle
Jul 31, 2006 09:51 PM
Steve in Seattle
Jul 16, 2006 11:46 PM
