Tb bypass
Old Jan 6, 2015 | 01:42 PM
blac94Z's Avatar
Tb bypass
So i was reading and i wanted
to verify before i do it this weekend
if there is a certain way to do it on
a 94 ?
Old Jan 6, 2015 | 01:49 PM
Re: Tb bypass
Yes. 93/94 you take the two coolant hoses off the bottom plate of the throttle body and connect the rubber hoses together using a 3/8" hose barb, and a couple clamps.
95-97 is different, and does not require the hose barb, and discards one of the pieces.
In all years:
.... DO NOT SPILL COOLANT ON THE OPTISPARK DISTRIBUTOR.
.... REFILL THE COOLANT SYSTEM AND BE SURE TO BLEED ALL AIR OUT OF THE SYSTEM.
Capping the connections on the throttle body bottom plate with vacuum caps is optional, and makes no difference, one way or the other.
Old Jan 6, 2015 | 04:29 PM
blac94Z's Avatar
Re: Tb bypass
Great thanks alot Fred . Now is this just a waste of time or does it make a difference ?
IM NOT SAYING SEAT OF PANTS DIFFERENCE BUT FWHP OR RWHP TQ ANYTHING ?
Old Jan 7, 2015 | 08:57 AM
Re: Tb bypass
Dyno results = +6.3 peak HP at the rear wheels:
Modifications #8
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
