Tb bypass
Re: Tb bypass
Yes. 93/94 you take the two coolant hoses off the bottom plate of the throttle body and connect the rubber hoses together using a 3/8" hose barb, and a couple clamps.
95-97 is different, and does not require the hose barb, and discards one of the pieces.
In all years:
.... DO NOT SPILL COOLANT ON THE OPTISPARK DISTRIBUTOR.
.... REFILL THE COOLANT SYSTEM AND BE SURE TO BLEED ALL AIR OUT OF THE SYSTEM.
Capping the connections on the throttle body bottom plate with vacuum caps is optional, and makes no difference, one way or the other.
In all years:
colts0455
Sep 2, 2015 12:41 PM
