TB Bypass
Old Jul 14, 2005 | 10:50 AM
1993Fast_Z's Avatar
TB Bypass
i have a question....do you think that the TB Bypass could cause my temp. to go up slightly? i dont know if i want it on there
Old Jul 14, 2005 | 10:59 AM
BUBBA's Avatar
Re: TB Bypass
Not if you do it correctly, i.e., do not plug the metal tube coming from the heads, but route it directly to the radiator in order to relieve the hot coolant from the heads.JMHO
Old Jul 14, 2005 | 11:00 AM
joeSS97's Avatar
Re: TB Bypass
No.
Crazy95Z's Avatar
Re: TB Bypass
I doubt it. The coolant running through the throttle body isn't really designed for cooling purposes, it's for in the winter to heat up the throttle body to make sure it doesn't freeze, even though to some degree I'm sure it cools the exiting coolant, but is minimal at best. You shouldn't notice any rise in temperature.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
