TB bypass???
Old Jun 28, 2005 | 09:02 PM
z28camaro350's Avatar
TB bypass???
hi i want to do a tb bypass on my car i was wondering what materials i will need and what gains i could expect out of this. i wanted to know what the general purpose is. with doing this will can i still use my airfoil or does that not matter anymore.
thanksss craig
Old Jun 28, 2005 | 09:25 PM
magnumv8's Avatar
Re: TB bypass???
You wont see much gain, but it is a cheap mod. It just re-routes the coolant so your not putting hot coolant through the throttle body. It has no effect on the use of an airfoil.
You should do a search on here about this and you can find a lot of info.
Welcome to the site.
Old Jun 28, 2005 | 10:45 PM
OBE1 95Z28's Avatar
Re: TB bypass???
GM routes coolant though a small manifold attached to the bottom of the TB. It's purpose is to prevent icing of the TB that may occur in extremely cold weather. Of course during warmer weather, it's just heating up the TB. Colder air is denser than warmer air and therefore makes more power, although in this case it's a small gain. If you look at the bottom of your TB, you'll see 2 hoses that connect to it. Basically bypassing involves disconnecting these two hoeses and rerouting them to connect to each other.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
