TB Bypass
Old Jan 14, 2005 | 05:43 PM
JAG05's Avatar
TB Bypass
Ok i've been looking at this TB bypass and it looks simple. It looks like its just a hose a metal piece and some rubber stoppy things.. So is it possable to make it myself? Has anyone made there on?
Old Jan 14, 2005 | 05:46 PM
americanmusscle's Avatar
Re: TB Bypass
http://shbox.com/1/tb_bypass.jpg
Image brought to you by shoebox a.k.a. the man.
Oops didnt see you had a 94 z its basicly the same thing but you have to have a conector instead of attaching it to the side of the intake.
Old Jan 14, 2005 | 06:17 PM
Antz97ZNJ's Avatar
Re: TB Bypass
www.ws6.com
Old Jan 14, 2005 | 11:52 PM
Re: TB Bypass
All you need is a 3/8" barbed brass hose connector and 2 worm clamps to fit the hoses. The 3/8" vacuum caps for the TB connections are optional, just to keep dirt out.
Old Jan 15, 2005 | 02:55 AM
FireHawk409's Avatar
Re: TB Bypass
I dont know if i can explain this right but here it goes. I took the hose thats on the passenger side off a coolant line and reconnected to the other side of the TB. So it makes one loop. Then whatever was left i just capped off with vaccum caps, i put some black rtv in the caps to make sure they stay on. Not sure if that was a good idea or not. Hope i explained it well.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
