Taylor OTVC kit owners - question
Old Apr 6, 2006 | 08:51 PM
DarkHorse's Avatar
I'm getting an oil leak seeping from underneath the hold downs on the valve cover - did the kit come with some sort of gasket/o-ring/washer that sits underneath of the wire brackets?
Seems the oil is climbing the bolts and seeping from underneath there - anyone else experience this? I'm going to try either small rubber o-rings underneath or nylon washers.
Old Apr 6, 2006 | 08:54 PM
DarkHorse's Avatar
Re: Taylor OTVC kit owners - question
Has me wondering now if I have a clean surface underneath. I'll get them off tomorrow and see. Hate oil leaks!
Old Apr 6, 2006 | 11:12 PM
97formulakid's Avatar
I have made for you wire looms and they didnt come with any gaskets or anything. The stock washers that are on the stock valve cover bolts won't fit over the new bolts so I just left them off. I've been checking them and so far so good.
Old Apr 6, 2006 | 11:35 PM
ibanez6rg's Avatar
I have the same problem. Still trying to figure out a way to get it fixed.
Old Apr 6, 2006 | 11:36 PM
DarkHorse's Avatar
Good to hear (sorry) that i'm not the only one. I'll let you know if the o-ring or washer solution works.
Old Apr 7, 2006 | 08:14 AM
wrd1972's Avatar
Same problem here. What we need is either aluminum or brass washers that are conforming to seal it off. Still looking.
Old Apr 7, 2006 | 08:22 AM
scottslt1z28's Avatar
took mine off..............cause i kept burning them up, so i ran them in the stock location with regular bolts (mine did leak a tad with the OVT kit though), but hasnt done it since i switched back to the stock bolts and ran the wires the orignial way.
Only reason i kept burning them was because i tried to install them with stock manifolds (that didnt work to well........lol)
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
CobraEatr
Jul 22, 2002 09:49 AM
