???? on a cc306 cam
Old Apr 5, 2006 | 03:31 PM
toofast10's Avatar
Smile ???? on a cc306 cam
i just wanted to know if i would have any problems with clearence with a 306 cam wit stock head and everything... I know i have to change the springs... but will this be a good choice for a daily drive M6 car??? I have basicly most of the basic bolt-ons.... but want to run a good cam on the car.. and i see that everybody mostly everybody have told me this will be a good cam.... I just want to double check before i buy it.... thanx
Old Apr 5, 2006 | 03:33 PM
93transam1234's Avatar
Re: ???? on a cc306 cam
If i where you i would go with a cuton grind cam from someone like Joe O
Old Apr 5, 2006 | 05:42 PM
ajschult's Avatar
I agree, Joe O or Bret Bauer. You can get exactly what you want and price is about the same. A 306 would probably be fine for a daily driven 6 speed however.
Old Apr 5, 2006 | 05:47 PM
snakeatinZ's Avatar
cc306 It is perfect for daily driven six speed.
Old Apr 5, 2006 | 07:41 PM
toofast10's Avatar
but i wont have any problem with the spacing???
Old Apr 5, 2006 | 09:28 PM
Jazsun's Avatar
what about millage on the cc306 daily driver? Does it get worse then normal?
Old Apr 5, 2006 | 10:19 PM
Sleeper_Z's Avatar
My car is a daily driven 6-speed with a CC306 and i get between 18-20 on average. AND I dont drive lightly. I could probibly get around 22 if i took it easy. But with the power that the CC306 makes up top its hard not to tap into it getting on the interstate
Jeremy
Old Apr 5, 2006 | 11:31 PM
Josh'95Z28conv's Avatar
I have a custom grind Joe O cam that I just pulled out of my old shortblock. Its supposed to make the same power as a cc306, but starting at a lower rpm, so it should be better driving on the street. My new engine will be going in soon with a custom Bret Baur cam, so If you are interested PM me and Ill hook ya up
Old Apr 6, 2006 | 08:48 AM
Jazsun's Avatar
Doesnt the LT4 hot cam lope a lot more then a cc306, can you hear the cc306 lope?
Old Apr 6, 2006 | 01:34 PM
Sleeper_Z's Avatar
The hot cam actually sounds pretty weak in comparison. Here is a few vids of mine befor and after the tune. The first vid is befor the tune with a 650rpm idle. The second is after the tune with a 1050rpm idle to calm down the lope so I could actually get some people to play
http://videos.streetfire.net/video/3...B53BBB5684.htm
http://videos.streetfire.net/search/...169FC1DF6B.htm
The hot cam is almost un noticable with an idle around 1000rpm.
Jeremy
Old Apr 6, 2006 | 02:03 PM
OffspringZ28's Avatar
meh. XE224/230 is the ultimate daily driver cam. my old car with that cam pulled a couple 306'd 6 speed cars
Old Apr 6, 2006 | 02:12 PM
jsetzer's Avatar
cc306 is a baby cam. Had it and loved it. Went with a gm847 in the new motor after spinning a couple of bearings last year.
cc306 has a nice lope
gets nearly stock fuel mileage "IF" you baby it
pretty easy to tune for
will go with stock heads no problem, new springs at minimum, I suggest new rockers. I broke one of the stock stamped rockers on my cc306.
Old Apr 6, 2006 | 03:19 PM
Jazsun's Avatar
Do you always have to idel at around 1000 rpm? Id think that would be bad for bumper to bumper traffic which I see a lot.
Old Apr 6, 2006 | 03:22 PM
jsetzer's Avatar
I set my idle at 650 with my cc306.Sounded nice. On a stick shift car (especially if you have gears) stock or even a little lower is fine. With an auto it would helpt to keep the car from stalling.
Old Apr 6, 2006 | 07:31 PM
toofast10's Avatar
hey but will u have enough cleareace with 1.6 rr... because i dont want to mess with the heads...
