Taller Valvecovers???
Old Mar 29, 2006 | 09:53 PM
niksmoov's Avatar
Question Taller Valvecovers???
With taller valvecovers how or where do you install the alternator?
(Alternator is in the way???)
Old Mar 29, 2006 | 10:20 PM
1racerdude's Avatar
Re: Taller Valvecovers???
Ya have to put the same notch as is in the factory cover in them.
Old Mar 30, 2006 | 04:16 AM
Sporty-X's Avatar
i made mine fit with a little grind on alternator. I don't think it can work with all of tall valve covers anyway.
There is also a post on someone selling a part to rise alternator
Old Mar 30, 2006 | 04:21 AM
SVThuh's Avatar
Just mark and grind the back of the alternator... Works wonders and is WAY cheaper than the alternative of the alternator relocation bracket. Good Luck!
Old Mar 30, 2006 | 07:20 PM
Josh'95Z28conv's Avatar
You should try searching, or looking on the first page. There are two different threads about this on the first page of LT1 tech.
You can grind the alternator, or install a ~$30 alternator lift bracket to get the alternator out of the way.
Old Mar 30, 2006 | 07:34 PM
1racerdude's Avatar
Josh
Where would one get the lift bracket?
Old Mar 30, 2006 | 08:25 PM
thesoundandthefury's Avatar
Originally Posted by 1racerdude
Josh
Here's a link to the ad:
http://www.jdrcustom.com/Zoops-8175-8176.html
The person who originally found these had mentioned something to the effect that they're supposed to be adjustable, but this ad shows that they're set at a fixed 1 1/4" height. They're also designed to work specifically with Zoops' LS1 brackets; I'm sure if somebody was handy with a grinder it wouldn't take much if anything to get them to fit a stock LT1 accessory bracket though. However, the thing that concerns me is hood clearance...
Old Mar 30, 2006 | 08:28 PM
1racerdude's Avatar
Thanks for the link.
That DOES set it up pretty tall and I think clearance might be an issue.
Old Mar 30, 2006 | 09:46 PM
http://web.camaross.com/forums/showthread.php?t=432228 Check out post #12. That guy has one and says its adjustable. Just get it hight enough to clear, and he says clearance isnt an issue
Old Mar 30, 2006 | 09:51 PM
1racerdude's Avatar
Thanks,that's good to know. Will be trying one.
Old Mar 30, 2006 | 09:53 PM
Me too, since I bought a pair of polished aluminum valve covers from the classifieds, to only later find out they werent LT1 covers, lol. My engine should be ready <2 months.
Old Mar 30, 2006 | 10:01 PM
1racerdude's Avatar
Mine should be ready in??? When the rest of the car is ready???
Old Mar 31, 2006 | 07:47 AM
Originally Posted by dutss707
Zoops has a "Riser Bracket Alternator" #8175 which would
allow about a 1.4 or 1.5" movement to allow for tall valve
covers. Oh yeah...cost = $31.95., and believe it's Billet.
that is up to 1 1/4" adjust. possible for the Zoops Riser bracket #8175
you may only need a 1/4" adjust. Zoops sells them for this purpose
clearance is not a problem with the hood.
Two things:
1. I don't see anywhere in that guy's posts where he says he has one of these brackets.
2. Did you actually click on the link and READ the ad for this bracket? The bracket increases the height by a fixed 1 1/4" difference. Nowhere does it mention that it's adjustable.
I understand that the original poster was trying to help but even still we need to be discerning and figure stuff out for ourselves instead of blindly believing every tidbit of info that we read about here.
Old Mar 31, 2006 | 07:30 PM
Two things:
Now that you point that out, it does look like a fixed riser. I wonder if this guy really knows what he's talking about.
Old Apr 1, 2006 | 02:22 AM
blown383's Avatar
We need pics of this thing installed! Also with a riser like that wouldn't one need a longer serpentine belt?
-B
Chophouse
Jun 18, 2015 08:25 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Dave Feerst
Jun 14, 2003 04:49 PM
donot_4get
Jan 20, 2003 05:06 PM
