Tall Valve Covers
Don't count on being able to just grind down the alternator and bolt it on. My valve covers are not very tall and grinding was not enough. I cut out the back of the alt. case entirely (where it was hitting) and then grinded downt the face of the valve cover. It still would not fit. All valve covers are different so there is no telling if it will work or not.
Also, if you grind on the alternator, think about where the shavings are going. The are going to fall inside the case. Plan on taking the case apart to blow it out at least (you don't want shavings in the bearings). Remember, if you grind on the case of the alternator, you can never use it as a core if the alternator goes out. I wish I would have done it right the first time and notched the valve cover right away, or bought ones that had a notch. Now I have a grinded alternator and I still had to notch the valve cover.
Dustin
Dustin
Originally posted by kmook
I'd like to get an actual height mesurement of those valve covers because from just looking at the pics they look like aftermarket covers but not really "Tall" covers.
When you said "Tall" I think of something like these-
http://store.summitracing.com/partde...57#largerimage
That are like 5" high in the center, in which case you'd have to grind like 1/4 of the alternator off
scroll down to part number 141-132 GM12497985, the not for LT 1 ones!
Jsut goign to get the New Covers Notched...At least this way I know that I can sleep well at night knowing I can run an Agressive *** cam without worrying about any thing hitting. The more I get to working on my car the more flaws I realize about these things. They should have relocated the ABS module and but the Alti on the Vette side.
LOL.. I have replied to this a billion and a half times... I'll copy my old posts.... Theres a ton of clearance for the rockers etc...
OR you can do what I did.... They sell these in chrome, polished (what i have) or black (what I wanted)
here are some tips...
http://members.***.net/eplanajr/cart...nd1%20tips.JPG
finished alternator...
http://members.***.net/eplanajr/cart...atorgrind1.jpg
this is what i need the valve covers to clear...
http://members.***.net/eplanajr/cartech/motor1.jpg
assembled...
http://members.***.net/eplanajr/cartech/motor2.jpg
http://members.***.net/eplanajr/cartech/motor3.jpg
great pic of assembled view...
http://members.***.net/eplanajr/cartech/motor4.jpg
Heres a few better pics of the passenger side area...
right behind the alterator
http://members.***.net/eplanajr/cart...BZODMotor1.JPG
heres the gap between the alternator and the valve cover. it is about 1.5mm to 2mm, its more than it looks.
http://members.***.net/eplanajr/cart...BZODMotor2.JPG
front view of how bad *** it is
http://members.***.net/eplanajr/cart...BZODMotor3.JPG
side view....
http://members.***.net/eplanajr/cart...BZODMotor4.JPG
assembled...
side view....
Originally posted by jim88iroc305
http://www.salleechevrolet.com/Profo...ve_covers.html
I'm using the GM 141-132's. I only had to clearance the back of the alternator slightly to get them to fit.
There's pictures on my web site. Click on the 2 top left pictures of the engine.
Frank
Frank
carguyshu
Jan 22, 2017 11:19 AM
