Taking out rad, any tips?
Old Mar 13, 2006 | 10:18 PM
danny525's Avatar
Question Taking out rad, any tips?
Got a big leak in the rad, so its coming out and too a shop, hope its fixable. Just seeing it there is any tips anyone has for this procedure.
Old Mar 13, 2006 | 10:26 PM
96ZCamaro's Avatar
Re: Taking out rad, any tips?
If I were you I would just try and find a new cheap radiator with a lifetime warantee instead of trying to fix an old one. But I think taking it out would be almost the same as on any other car.
Old Mar 13, 2006 | 10:55 PM
94Z28WP's Avatar
It's pretty simple... Slip the a/c condenser out of the slots at the front of the radiator if it's connected... Disconnect the radiator hoses... If it's an A4, remove the trans cooler lines from the radiator and plug them... Unplug the fans... You might be able to get it out with the fans still attached.. If you do, you'll probably need to snap the fan wiring out of their connectors on the fan shroud... If it won't come out with the fans, you'll need to get underneath and push up on the fan shroud to remove it from the slots on the radiator... That's all I can think of.
Old Mar 13, 2006 | 10:56 PM
Evil Eric's Avatar
Make sure you have the car up high snough to take all of the coolant lines loose before you try to remove it. just taking the drain plug out of the bottom wont get all of the coolant out of the lines.
Old Mar 14, 2006 | 12:28 AM
danny525's Avatar
i found a new rad for sale, but its off a 97- im pretty sure its not a problem, almost 100% but it never hurts to double check. Am i good- its going in the 96.
Old Mar 14, 2006 | 08:53 PM
danny525's Avatar
97 rad fit in a 96- anyone?
Old Mar 14, 2006 | 11:30 PM
94Z28WP's Avatar
Yep.
Victor Lamb
Aug 26, 2017 02:52 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Darth Xed
Jul 1, 2002 03:22 PM
