taking off rear shocks and the nut keeps spinning
Old Feb 23, 2003 | 06:50 PM
ZDriver96's Avatar
Ok im taking off the rear shocks.
I peeled back the carpet and got to the bolt that holds the top of the shock in.
I put a 15mm deep socket on it and it just kept rotating and the nut did not back out.
Im guessing you have to get a wrench on that nut and hold the top of the bolt so it doesnt rotate with the nut?
If so thats gonna be a pain in the ***.
Old Feb 23, 2003 | 07:02 PM
DirtyDan's Avatar
I always used a pair of vise grips on the shaft if I am going to be replacing them. Kindof caveman like but it works.
Dan
Old Feb 23, 2003 | 08:04 PM
Spray some lube on the stud. Once you get it broken loose, the nut will usually spin right off. I think a 1/4 open end wrench will fit the top.
bossco
Nov 29, 2014 10:18 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
slothgrant
Aug 22, 2002 03:01 PM
