Taking apart the optispark
Old Feb 24, 2004 | 05:28 PM
jj93z28's Avatar
I seem to remember a site that showed you how to disasemble the opti to look for damage. Anyone know the url? Thanks
Old Feb 24, 2004 | 06:44 PM
jj93z28's Avatar
found it myself.... here it is should anyone else be interested.
http://www.charm.net/~mchaney/optisprk/optisprk.htm
Old Feb 24, 2004 | 09:46 PM
Alex94TAGT's Avatar
Why exactly are you taking apart your optispark? Car stumbling?
That site is for tearing apart a 1995 opti. The pre-95 opti's are a little different. Specifically, you'll have a little bit of trouble with the photo emitter and the slotted disc. Unlike the '95, our slotted disc is spotwelded to the bearing behind it (cant/shouldn't be removed), and there are two somewhat hidden (T-20) torx bolts underneath that disc that hold the bearing to the metal back-plate. So, you have to pry up on the disc to get to the bolts (WITHOUT BENDING THE DISC!!!). Otherwise, you'll never get the opti fully disassembled.
I vented my stock 94 opti a while back, so I 've got photos explaining all of this if you need them. I've also got a few tips while you're in there. Shoot me an e-mail if you wish...
Old Feb 24, 2004 | 09:57 PM
Mtrhds94Z's Avatar
The bearing isnt welded to the shaft, [that the disc is welded to]but yes it is tricky to get out..and there is no replacement bearing available, and that is usually bad[3 of 4 I have taken apart had bad bearings]
Old Feb 24, 2004 | 10:02 PM
Alex94TAGT's Avatar
I stand corrected. "Bearing assembly"
It's all one piece...
Old Feb 25, 2004 | 12:55 PM
jj93z28's Avatar
I put a hotcam in a few months back, the car has not ran since. I just put a new timing chain and figured I would take a look inside the opti while it was off. I am just about to put the battery in and see if she will start(I doubt it).
TitoPR221
May 26, 2015 12:20 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
Darth Xed
Jul 1, 2002 03:22 PM
