Takes/put in pistons from the bottom?
Old Apr 7, 2008 | 04:47 PM
  #16
sam pace's Avatar
Originally Posted by jasonface
Yep, the main bulkheads are in the way. I'm not sure you could even get it back in, good luck getting a ring compressor up in there. Do it out the top, head gaskets aren't that expensive.
You don'even need one, just take your time.
Old Apr 7, 2008 | 05:09 PM
  #17
rskrause's Avatar
Moderator
Putting in pistons w/o a ring compressor is an exercise that can be very annoying. In can be done, sort of. Not a good time, and I enjoy putting stuff together. But not that. The fixed size tapered sleeve is FAR better than the adjustable clamp type, but you need one for each bore size you do.
Rich
Old Apr 7, 2008 | 06:41 PM
  #18
mdacton's Avatar
Rich
they have tapered adjustable sleeves out now too. They don't adjust that much but still better than the clamp type.
Always get your block chamfered after a bore/hone.....make it alot easier. And you won't break any rings
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
