Taillight issue
Old Jan 1, 2005 | 12:47 PM
jbsupra89t's Avatar
Taillight issue
Hey,
So my blinker was "sticking" leading me to believe I had a bulb out. Front one worked fine, so I tested the rears today. Rear driver side is what I came up with. So I changed out both since I had two lying around. Tried it again, same thing. But when I jiggled the taillight assembly around a little, it started to work. Then it'd quit. I hit the hazards, and everything was blinking. But, 3 out of 4 of the rear lights that blink, blink bright. 1 however, isn't nearly as bright as the others, which would lead me to believe why the car thinks I have one out. The rear driver sidemarker is the same way. Dimmer than the pass. side. Any clue why these two are dimmer than the rest? I am somewhat at a loss.
-J
Old Jan 1, 2005 | 06:52 PM
jbsupra89t's Avatar
Re: Taillight issue
Bump, any ideas?
Old Jan 1, 2005 | 07:11 PM
slopokrodrigez's Avatar
Re: Taillight issue
You either have a bad connection or a bad (in this case 2) bulb. Try changing the 2 dim ones. If that doesn't help, measure the voltage at the socket and compare it to that of another "good" socket. If the voltage is lower, trace it back to the source.
Old Jan 1, 2005 | 09:12 PM
jbsupra89t's Avatar
Re: Taillight issue
Will do I'll give that a shot. Worked fine when I got the car 10k miles ago, wonder what ended up going... thanks for the insights
-J
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
karguy16
Mar 6, 2015 01:31 AM
Alex Barnes
Jan 24, 2015 10:21 PM
weaponZ
Jun 6, 2002 07:29 AM
