Hey all I finally got to dyno my motor.
Just thought somebody might like a look
350 stroke 45over pistons
Forged zero decked hyd roller smogable
Ported LT1 Heads 293CFM 290w/intake
Edelbrock shorties 2.5 pipe
Self built trans w/ edge converter
Dynapack load dyno SAE corr. unlocked converter
The RPMS are sliglty off cause the dynaopack is calulated RPM, I calibrated it but this run was from 4K to 6.8K
Check out massive TQ multiplacation below stall
and how sharp the Edge converter couples at 4.5K RPM!
I'm very happy with the real world results it lays right on the curve I had in Engine Analyzer when I built the virtual model.
Now if I could only hook it up!!
Nice!
No sorry, I haven't been on the dyno since the rebuild. He'll I've only got about 250 miles on i due to opti failures. I'll be getting my LTCC setup by the end of this month then I'll post my dyno numbers after I get tuned.
