Tad's 357 LT1 Build
Old Jun 15, 2007 | 08:27 PM
TurboSS's Avatar
Tad's 357 LT1 Build
Hey all I finally got to dyno my motor.
Just thought somebody might like a look
350 stroke 45over pistons
Forged zero decked hyd roller smogable
Ported LT1 Heads 293CFM 290w/intake
Edelbrock shorties 2.5 pipe
Self built trans w/ edge converter
Dynapack load dyno SAE corr. unlocked converter
The RPMS are sliglty off cause the dynaopack is calulated RPM, I calibrated it but this run was from 4K to 6.8K
Check out massive TQ multiplacation below stall
and how sharp the Edge converter couples at 4.5K RPM!
I'm very happy with the real world results it lays right on the curve I had in Engine Analyzer when I built the virtual model.
Now if I could only hook it up!!
Old Jun 15, 2007 | 08:55 PM
mattbailey's Avatar
Nice!
Old Jun 16, 2007 | 12:24 AM
TurboSS's Avatar
Your combo look kinda close to mine do you have a dyno posted anywere?
Old Jun 16, 2007 | 09:15 AM
mattbailey's Avatar
No sorry, I haven't been on the dyno since the rebuild. He'll I've only got about 250 miles on i due to opti failures. I'll be getting my LTCC setup by the end of this month then I'll post my dyno numbers after I get tuned.
Old Jun 17, 2007 | 10:20 PM
JmalibuSS's Avatar
Keep in mind peeps that this is a nearly smooth idling engine! That should also pass smog.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
transam_388
Mar 15, 2015 11:53 AM
Jrlt1
Jan 3, 2015 07:38 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
