Tach Wiring Question...
Old Apr 11, 2006 | 11:53 AM
johnny3986's Avatar
I need to know if:
A) our tach output wire is connected to the coil (like it has an individual coil per wire)
B) The tach wire is connected to the tach from the engine electronic controller
or I know it isn't possible (but these directions listed it)
C) coil packs that fire in pairs and the the tach wire is connected to the coil.
It is a stock ignition system for those that might be wondering.
Thanks you guys!! You are indirectly helping me hook up my N20...
Old Apr 11, 2006 | 11:59 AM
Colin91Z's Avatar
Re: Tach Wiring Question...
I think I can answer A) for ya, the tach output wire is the white one coming off of the Ignition control module, this is where my auto meter tach get its reading from anyway...
Old Apr 11, 2006 | 12:09 PM
johnny3986's Avatar
Where is the ignition control module located at?
Does this seem right to everyone else?
Old Apr 11, 2006 | 12:14 PM
The stock tach is driven off the PCM pin A13. The white wire on the ICM connects to pin B5.
When you need wiring diagrams, or photos showing component locations, use Shoebox's website:
http://shbox.com/1/coil_loc.jpg
http://shbox.com/1/4th_gen_tech1.html
Old Apr 11, 2006 | 02:53 PM
Colin91Z's Avatar
Ok so does this mean I should change where my tach is getting its signal from to the A13 pin then? I was told by autometer that the white wire that I was refering to is where to get the signal from, are they right or wrong?
For the record, my tach seems to work fine...as far as I know anyway, but is nowhere near cosistant with my factory tach. I always just assumed that the factory one was off a bit and the autometer was dead on...could it be the other way around?
Old Apr 11, 2006 | 03:22 PM
GetaZforgetGT's Avatar
Factory tach normally stands a few hundred RPM higher than what the PCM is actually reading.
IE PCM sees 2500 rpm but tach may read 2800.
This is the case on my car for sure and many others have said the same thing.
Old Apr 11, 2006 | 03:58 PM
You're going to get a similar signal from either pin.
Old Apr 11, 2006 | 04:11 PM
WS Sick's Avatar
I have wired tachs from both locations and they read pretty well the same thing. Its cleaner and easier though just to take the white PCM lead (from PCM) since its already under the dash.
Old Apr 11, 2006 | 04:42 PM
Colin91Z's Avatar
Ok well I think I'll just leave mine way it is if its not gonna make a difference, being as its loomed neatly out of sight and everything. Thanks for the advice
Old Apr 12, 2006 | 03:11 PM
johnny3986's Avatar
So take it off the computer, but is it A, B, or C?
'A' has been answered
But 'B' seems more likely now though...
Old Sep 21, 2007 | 06:20 AM
93DGTA's Avatar
Is this true on a 93 also? Trying to track this info down getting ready to put auto meter in with shift light
Old Sep 21, 2007 | 07:00 AM
The white wire in cavity "B" of the ICM plug will probably work. However the 1993 tach gets its feed directly from another white wire on the coil plug that later years do not have. That wire has a little filter on it.
If you access C230 under the RH kick panel, you can tap into cavity "D" (same white wire coming from the 1993 coil) that feeds the factory tach. That will keep you from having to run a wire under the hood.
C230, cavity "D" is the tach feed for any 93-97, regardless of whether it comes from the coil or PCM.
Old Sep 21, 2007 | 11:20 AM
93DGTA's Avatar
Ok thanks
Old May 13, 2009 | 09:44 PM
Kory 88 Iroc Lt-1's Avatar
Thanks for the info. I was looking for this.
Kory
Old May 13, 2009 | 10:13 PM
Kory
Kudos for finding it with the search!
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
