Which tach wire for shift light?
Old Aug 9, 2003 | 05:17 PM
96z's Avatar
96z
Which tach wire did you guys use when you wired your shift light? I know there is the white one of the PCM but I remember somone telling me that the white wire that goes to the Ignition Control Module/Coil could be used...
Old Aug 9, 2003 | 09:12 PM
my96z's Avatar
I am pretty sure its the white wire off the ignition coil. But if you have a MSD you can run it off of that.
Jeff
Old Aug 10, 2003 | 02:02 AM
96 WS6's Avatar
white wire off the coil
Old Aug 10, 2003 | 10:32 AM
96z's Avatar
96z
I looked and there isnt a white wire off of the coil, it comes off of the ICM???, above the coil..
Old Aug 10, 2003 | 01:45 PM
96 WS6's Avatar
it's the connector with 4 wires not 3. I thought it was the coil but I could have been mistaken.
Old Aug 10, 2003 | 02:07 PM
94formulabz's Avatar
The White wire off of the PCM 'Red connector' (the harness isn't really red, but it's labeled "red' on the cast case), think it's 13 or somethin. Then it was right there to run through the firewall.
gl
brent
mr28
Apr 20, 2016 05:44 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
GigaMp3z
Feb 20, 2003 02:57 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
