Which tach wire for shift light?
Which tach wire did you guys use when you wired your shift light? I know there is the white one of the PCM but I remember somone telling me that the white wire that goes to the Ignition Control Module/Coil could be used...
The White wire off of the PCM 'Red connector' (the harness isn't really red, but it's labeled "red' on the cast case), think it's 13 or somethin. Then it was right there to run through the firewall.
gl
brent
gl
brent
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
