Tach Verification
Old Sep 24, 2003 | 01:18 PM
S8ER95Z's Avatar
Tach Verification
Ive heard something before about our tach not being accurate? Is there anyway to verify your tach?
Old Sep 24, 2003 | 01:21 PM
Hook up a "scanner" and read the PCM. It will give you the correct RPM.
Old Sep 24, 2003 | 02:10 PM
94formulabz's Avatar
some other options:
go dyno your car and check versus the dyno output.
Get a shiftlight and compare.
Your idle should be easy, then just check the high end by running it to the rev limiter.
Ok, so the scanner is probably a better option but i you don't have one then there are some other choices. I've found mine to be dead on accurate using the above 3 methods (i didn't go on a quest one afternoon, they were different times).
Not everyones tach is off like some people make it sound. I've had people ask me where i shift and then for some reason try to factually tell me that " you do know that your tach is off."
-brent
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
