Tach just went crazy!!
Old Mar 28, 2003 | 09:51 AM
bachehbad's Avatar
Ok my tachometer all of a sudden went crazy today....
it was working fine then all of a sudden it glitched a bit, then a few seconds later it was going crazy bouncing from 0-1000RPM
now the car idles fine and runs perfectly... what do you guys think happened??? Is this going to be an expensive fix?
Old Mar 28, 2003 | 10:00 AM
James3219's Avatar
Was the tach the only one that did this. About a year ago, all my gauges started doing this on a trip back from Florida and then the car died. It was the ignition switch under the dash. I am not sure if this is the same as what is happening to your car, but its almost the same symptoms.
Old Mar 28, 2003 | 10:54 AM
bachehbad's Avatar
nah, all other gauges are fine, just the tach
Old Mar 30, 2003 | 03:23 AM
bachehbad's Avatar
hrmmm left the car off overnight, in the morning i turned it on and the tach is now fine... what gives!?!?!?
Old Mar 30, 2003 | 04:43 AM
Laymaster's Avatar
My guess..and it is the ever popular guess on this board, is that your opti is going. Your tach readings come off the opti, and one of your sensors is going, or your opti is just going in general. When your tach jumped crazy from 0-1000, did your engine reflect that, or just your tach? When my opti died, it was on the highway, no warning, but it just died...then with the car in gear..a second later it'd restart itself, just come back on..it did that for about 30 seconds before it just died for good.
Old Mar 30, 2003 | 05:12 AM
Rx-7 SS's Avatar
Dude if it osnly your tach, id say check the wiring. I mean honstym if its your tach solo, its propaly a problem in thatdepartmenbt. Chech that **** ou before anyting esloe.
Old Mar 30, 2003 | 03:54 PM
bachehbad's Avatar
i fear that it is my opti going... becuase i feel an ever so slight stumbling in my car... when i say slight i mean very slight, before one of my spark plugs was arcing and it was a bad stumble... this is a very tiny stumble always below 2000RPM....
Old Mar 30, 2003 | 03:59 PM
bachehbad's Avatar
oh and laymaster, no my engine didnt reflect what was going on with the tach..... engine was driving fine....
Old Mar 30, 2003 | 04:00 PM
ibanez6rg's Avatar
My tach does that occassionally. Mine kinda just freezes at certain points also. But it doesn't do that all the time. And it would just go back to normal if the car had just been sitting for awhile and them restarted. I was told by someone to clean the IAC sensor to see if that would help out my problem any. Good luck
Old Mar 30, 2003 | 04:03 PM
bachehbad's Avatar
ibane do you think u have problems with your Opti as well, or no?
Old Mar 30, 2003 | 06:50 PM
ibanez6rg's Avatar
No, I believe my opti is just fine. I'm having no problems with the motor at all and it runs really smooth. My tech just goes nuts sometimes
Old Apr 23, 2003 | 05:14 PM
guest's Avatar
my car does something like this too, when i'm accelerating and the motor is powering out/stumbling the tach will not go up in a smooth motion, it will go up in a jerky fashion, even though the car is accelerating in a smoother, but slow fashion.
Ryan Ramsaran
Sep 19, 2015 08:43 PM
mlopezart
Sep 8, 2015 12:15 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
