Synthetic Oil with manifold leak...
Old Jun 21, 2006 | 02:06 PM
RedRocketZ28's Avatar
I know there have been hundreds of posts about oil and what not but hopefully this is a little different. Right now my intake manifold is leaking and I should get it fixed but the funds wont allow for it right now. The leak is not too bad although I do need to keep a constant eye on the oil level. My question is will synthetic oil leak out faster than conventional oil? I thought I read somewhere that it might but I wanted to make sure before I made any decisions. Also, will it make any difference going from conventional to synthetic oil? My car has almost 55k on it now if that matters and I was wanting to switch to synthetic because it seems like most people are using that now. Thanks for the help in advance.
Andy
Old Jun 21, 2006 | 03:54 PM
BUBBA's Avatar
Re: Synthetic Oil with manifold leak...
Probably won't make any difference what oil use if you have a leak.
Won't hurt to change to dino oil---I use 10w-40 in my 97 and I only have about 1000 miles on the engine. The quality of oils today is such that a good brand dino oil will do the trick for less $$.
Consider getting that manifold leak fixed before you wind up with no oil and a broken motor. JMHO
Old Jun 21, 2006 | 05:59 PM
nb 96 z's Avatar
Try to change it yourself. It doesn't take much time to pull the intake manifold. You can get it done in a day easy and its not hard to do. You'll save a ton of money too.
Old Jun 21, 2006 | 07:42 PM
speed_demon24's Avatar
Yeah, do it yourself, all you need is new intake manifold gaskets and some red RTV. Shouldn't take more than a few hours.
rideordie
Nov 5, 2019 04:52 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nickster 7
May 1, 2015 09:04 PM
brentasan
Aug 1, 2004 11:19 PM
ssbee
Jun 12, 2002 12:03 PM
