Synthetic Oil
Re: Synthetic Oil
Originally Posted by Mindgame
n2ceptor.... master of the search engine. Yeah, I've noticed.
Perhaps you should give lessons.
-Mindgame
-Mindgame
90% of my time is researching on the net.... Most answers are out there, people just have to take the time and look for them.....
And read my sig....
Re: Synthetic Oil
Originally Posted by LT1Squirrel
so you think i should switch over to RP 10w30?
dave
ps- these statements are not meant to create any arguement. this is merely a representation of the facts as i have understood them.
Re: Synthetic Oil
M1 5w-30 is not a bad oil or particularly harmful just that for the same exact price and even in the same brand you can get better results with another viscosity so why use a oil proven to be not as good in this application. I have seen UOAs for it in other applications where it worked very well for a single 15K mile interval, but that was not an LT1 it was a VW 1.8T yes a turbo and 15K miles and it was good. On the RP thing I have read bad things about the street stuff shearing down to a thinner grade fast, the race stuff is supposed to be good.
Re: Synthetic Oil
In 3 pages, did anyone post dyno results?
A local dirt track engine builder found 5 - 7 hp switching from conventional to Royal Purple. Strangely, though, the gains weren't immediate. It was a 7500 rpm, 650 hp 350 that was their dyno mule. After switching to sythetic, it gained nothing at first, but picked up ~2 hp per dyno pull over the next 3 pulls.
Mike
Mike
Re: Synthetic Oil
If you look at the "thread" I found posted earlier in this one, its shows this...
They have just run tests on a FF 1100cc Racing engine and here are the results:
15W50 = 127.9 HP @ 9750 RPM, 75.8 Ft#'s @ 7300 RPM
(Racing Oil)
5W40 = 131.6 HP @ 9750 RPM, 77.7 Ft#'s @ 7400 RPM
(Racing Oil)
0W20 = 134.4 HP @ 9750 RPM, 78.9 Ft#'s @ 7400 RPM
(Advanced Development racing Oil
The lower viscosity shows a 5% HP gain and a 4% Tx gain.
The new 0W20 ADP Racing Oil is $11.73.qt. Comes in a 5 Liter (5.28qt) container.
The other Silkolene Full Synthetic racing oils (10W50, 5W40, 15W50) are around $8.50/qt. packaged in 5L containers.
2. Although I like the higher weight 15W50 Mobil 1 for Racing applications, I would not hesitate to use the Silkolene 0W20 Full Sythetic ADP Racing Oil.
(Racing Oil)
(Racing Oil)
Re: Synthetic Oil
RX Speed Works
Jul 24, 2015 02:25 PM
