Swithced OBDI to II What wire do I need for ALDL??
I have a 95Z that I have put a 96 computer in. I would like to be able to pull codes (OBDII) from the ALDL but there needs to be another wire run from the ECU to the connector under the dash. Does anyone know how this wire is labeled? Where can I get a factory assembly manual that would show this?
Thanks, Ryan
Thanks, Ryan
I got my GM manual from www.helminc.com. I can't help you on the other thing, I have OBD1.
I don't think you need any additional wires to pull codes (have you tried it?), but if you do, there is only one wire that is added with OBD-II. A purple wire from pin 2 of the DLC goes to C4 (blue)-pin 7 of the pcm.
