Swaybars..... Couple questions...
Old Dec 24, 2003 | 02:34 PM
Hyperspeed97z28's Avatar
Question Swaybars..... Couple questions...
Do these ever wear out like springs/shocks? and hows the 1LE's
32/19 front/rear's
Old Dec 24, 2003 | 02:47 PM
jkipp84's Avatar
I've never heard of sway bars wearing out, they're pretty much a static piece unlike those you mentioned.
As for the 1LE parts, they're supposed to be a nice improvement. I'd throw in some poly bushings with new end links as well.
Personally, I went the BMR www.bmrfabrication.com route for sway bars (and just about every other suspension part as well). They made a very noticeable improvement and having the choice of color is nice too.
Old Dec 24, 2003 | 02:50 PM
I bought a set of 1LE's for $112 to my door.. cant go wrong there. I plan on doing some poly bushing/end links for sure!
thanks for responding !!!
Old Dec 24, 2003 | 04:24 PM
Red_94Formula's Avatar
The bar will last forever but the bushings wont. Im not sure how long but check em every 25,000 for play and cracks
Old Dec 24, 2003 | 05:40 PM
I'm gonna replace the endlinks and bushings with the poly parts, we gotta have the best for our cars.
Old Dec 24, 2003 | 05:48 PM
bruecksteve's Avatar
1LE's aren't much better than what you had. You should have wandered down to the Road Race/Autocross Forum and asked there first.
I would have recommended the Suspension Techniques 35mm from bar to start with. Probably could have left the stock rear bar on for now. The front bar is $148 from Sam Strano (www.stranoparts.com). The 1LE bar is hollow and while it's lighter, it's not NEARLY as stiff as the 35mm solid bar.
Old Dec 26, 2003 | 06:50 AM
Well for the price I got them and what I use the car for it shouldnt matter to much... What matters to me is that its better then what I have on there and should add a bit of a stiffer ride....
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
