Swapping a T56 from a 383 stroker onto my LT1
Old Jan 19, 2023 | 08:18 AM
jakobhurd's Avatar
I have a 1995 z28 and absolutely loathe the fact that it has an A4. I found a 1995 z28 with a non running 383 stroker but a (hopefully) fully in tact t56. I started doing research because for the most part it seems like it should be a straight swap but I am getting confused with all the talk about 1 piece rear main seals and 2 piece rear main seals and can’t tell if I should prepare to buy a new flywheel or bellhousing etc. If there is a thread that already addresses this please let me know. 😁
Old Jan 19, 2023 | 09:39 AM
Chimera96's Avatar
Re: Swapping a T56 from a 383 stroker onto my LT1
If the donor 383 is a LT1 motor, the flywheel, bellhousing from the 95z T56 will bolt right up. Clutch is specific to LT1 as they are "pull" type
Old Jan 19, 2023 | 10:08 AM
jakobhurd's Avatar
Ah okay I think I got confused, so is there a “383 stroker” that is done on the sbc2 LT1s but also different 383 that is the older and a sbc 1? Idk how to put it into more proper terms.
Old Jan 19, 2023 | 10:16 AM
Chimera96's Avatar
yes a gen 1 SBC cane be "stroked" to 383 just like the Gen 2 LT1 that were in 95 camaro. My LT1 is now a 383 and I have a T56
curtis75
Classic Engine Tech
Sep 30, 2008 09:50 PM
bigbusa
Parts Wanted
Jan 29, 2007 01:23 AM
emtcee1973
3rd Gen / L98 Engine Tech
Oct 10, 2003 05:45 PM
Chris`s85Z28
16
Jan 27, 2003 11:27 PM
quick1
Nov 24, 2002 07:49 PM
