383 and t56
Old Oct 9, 2003 | 05:51 PM
emtcee1973's Avatar
383 and t56
here is what i want to do.i am going to build a 383 with a 1 pc seal block.then run a t56 trans behind that.here r my questions:
1) should i get an internaly balanced kit or externaly balanced,which is better?
2)can i use the stock t56 fywheel?
3)is the stock 1pc seal block internaly or externaly balanced?
4)which balancer do i need 400 or a 350?
Old Oct 9, 2003 | 06:10 PM
TheGreatJ's Avatar
The 350 is internally balanced. If you get an internally balanced 383 kit you can run a 350 balancer and a stock LT1 flywheel and you'll be fine.
Old Oct 9, 2003 | 06:32 PM
emtcee1973's Avatar
thanks but someone just told me today that the 1 pc seal motors r externaly balanced.which one is true?so you are saying that i will be able to use my stock flywheel and a 350 balancer if i go with the internal balace kit?
Old Oct 9, 2003 | 08:37 PM
Black6SpdTA's Avatar
What J said is correct, and a 1 piece rear main seal motor is internally balanced, the 350 anyway, which is what you'll be using to go 383 I assume. Good luck! What kind of car is it all going in?
-Rippin
Old Oct 10, 2003 | 05:45 PM
TheGreatJ's Avatar
All SBC's are internally balanced except the 400. The 1-piece RMS engines use a small counterweight on the flywheel to accomodate the newer seal design, but the crank throws still have counterweights and it's still an internally balanced engine.
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
