Swapping a T56 from a 383 stroker onto my LT1
I have a 1995 z28 and absolutely loathe the fact that it has an A4. I found a 1995 z28 with a non running 383 stroker but a (hopefully) fully in tact t56. I started doing research because for the most part it seems like it should be a straight swap but I am getting confused with all the talk about 1 piece rear main seals and 2 piece rear main seals and can’t tell if I should prepare to buy a new flywheel or bellhousing etc. If there is a thread that already addresses this please let me know. 😁
Re: Swapping a T56 from a 383 stroker onto my LT1
Ah okay I think I got confused, so is there a “383 stroker” that is done on the sbc2 LT1s but also different 383 that is the older and a sbc 1? Idk how to put it into more proper terms.
