Swapping PCM?
Old May 29, 2007 | 02:32 AM
Hood_Lum's Avatar
Swapping PCM?
Would a pcm from a 96 6 speed z28 work on a similar year automatic?
Old May 29, 2007 | 02:51 AM
bingo's Avatar
Yes, but the PCM would not be controlling the transmission unless it is reprogrammed.
Old May 29, 2007 | 07:29 AM
2000GTP's Avatar
Exactly, you would need to get it tuned for your application.
Old May 29, 2007 | 09:22 AM
Hood_Lum's Avatar
So would i be able to pass a smog test with the automatic using the 6 speed pcm? I'm in CA and they use the dyno smog test here.
Old May 29, 2007 | 09:47 AM
2000GTP's Avatar
The 94+ automatic trannies are electronic driven so the PCM is going to have a big part in their role. If you don't have the correct programming in the PCM, then I don't see it working.
Old May 29, 2007 | 09:23 PM
Hood_Lum's Avatar
Hey 2000,
Thanks for all your replies.
In case you're wondering, my friend has 96 auto but he fried his pcm.
I have an extra one since I'm using obd1.
Oliver
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
KamikaZ28
May 28, 2015 12:45 AM
jayvar
Feb 2, 2015 10:00 PM
Ricardo
Nov 29, 2014 10:58 AM
