swapping ls1 in place of lt1???
Old Feb 23, 2003 | 07:35 PM
cals400ex's Avatar
i was wondering how much trouble it would be swapping an ls1 in place of an lt1? i just wasn't sure if you would have to change everything under the hood for it all to work properly or not. thanks
Old Feb 23, 2003 | 07:47 PM
RobK's Avatar
There are some threads on this, but I've heard that a '98 LS1 would be the least amount of work due to the wiring changes done in '99. From what I've read, you need the full engine + accessories + computer + tranny--not sure what else. I think there is a problem with the gas tank too.
Old Feb 23, 2003 | 07:52 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
nothing bolts up
it will just as nhard to put in a ford 302 or an Lt5
Old Feb 23, 2003 | 08:32 PM
JulietZ28's Avatar
For the money it would take to do this u could probably have a pretty sweet stroker LT1 and rip those LS1's a new one
Old Feb 23, 2003 | 08:45 PM
Larnach's Avatar
I second what is said above... unless you're going ***** to the wall with an LS1, and need to save the weight, then do it, or just do whatever ya want
Old Feb 23, 2003 | 11:32 PM
Got-LT1's Avatar
I third what was said above.
Old Feb 23, 2003 | 11:39 PM
jonaddis84's Avatar
Why not throw in a Ramjet 502, probly less money, confined wiring harness, 500+ HP and torque, then throw a 300 shot on top of that, for less than a 400hp ls1 swap, more weight, but hey, nothing 800hp wont fix
Old Feb 24, 2003 | 12:13 AM
neil350's Avatar
LS1 are faster up to a point, you can still build a stout LT1 car for less or as much as the cost of that swap and its going to be helluav lot faster than a stock LS1. If it was like a third gen I could see, but an Lt1 is still fairly potent plat form and with the right cam and a good set of heads, you can build a beast.
Old Feb 24, 2003 | 12:36 AM
Dr.Mudge's Avatar
Its been done, unless my engine was dead, or I had money to spare (in a big way) I dont think I'd ever consider it, without just buying another car.
The engine is about an inch taller, so you may need a new hood, you could just try to get the whole front clip and use the fenders as well as an LS1 hood to fix that. I imagine the engine mounts are not the same, so you might want to nab thier crossmember too.
DirtyDaveW
Dec 1, 2016 05:37 PM
rocketman051894
Jan 30, 2015 03:23 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
ddr698
Jan 9, 2015 10:05 AM
