Swapping from 987's to 918's worth the $$?
Old Oct 22, 2005 | 04:23 AM
Capt'n Two Rotors's Avatar
Question Swapping from 987's to 918's worth the $$?
Hey guy's just like it say's I put in the 847 last spring and love it but I am wondering if I am leaving a little on the table with the 987's?? Would the swap be worth it? Also would I benefit from a AFR hydra rev kit? Thsi is all on a stock bottom end, stock heads car. Best et 7.89@89 in the 1/8.
Old Oct 22, 2005 | 12:02 PM
SStrokerAce's Avatar
Re: Swapping from 987's to 918's worth the $$?
The beehives would be a much better investment than the Hydra-Rev kit.
Bret
turbo_Z's Avatar
It would be cheaper to go with a hydra-rev and it will do the same as switching to the 918 springs if not an even better job. However I dont think you actually need the 918s for that cam since the ramp rates are fairly mild compared to some of the XEs. Guys used to say the 987s worked fine with the XE cams but now its the 918 springs... these things always change.
Old Oct 22, 2005 | 12:26 PM
Z95m6's Avatar
I'd think you would want to go with 918's. If you are running 1.6 rockers you are pushing those springs to the limit on lift.
Old Oct 22, 2005 | 02:00 PM
Unfortuneately the Hydra-Rev is not going to do a better job.
Old Oct 23, 2005 | 01:55 AM
So will I gain any power from doing this swap? I have read more on the rev kit and don't think I need it, I'm still on a stock bottom end and PCM.
Thanks for the input Guys
Old Oct 23, 2005 | 06:10 AM
JustNO's Avatar
26918 with Morel lifters (without hydra rev kit) is the BEST choice.
Old Oct 23, 2005 | 06:23 AM
Why would I need lifters mine are working just fine? I am using Sealed Power lifters
Devinfoote87
Feb 12, 2016 03:21 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
Boss002
Jul 24, 2015 10:47 AM
