Swapping a 96 LT1 into a 94, what needs to change?
Old Aug 18, 2009 | 07:20 PM
LS1_03's Avatar
Just like the title says. I tried searching but couldn't find what I wanted. I know a 96 motor is obd2, but is it a direct plugin to an obd1 harness? What would I need to change or swap, if anything?
Thanks in advance!
Old Aug 18, 2009 | 07:51 PM
JohnnyRage's Avatar
I have A 96 TA motor in my 94 z28 the only thing I needed was A 96 opti. been running good for 2 years now. I just left 96 timing cover on there
Old Aug 18, 2009 | 09:29 PM
LS1_03's Avatar
Thanks in advance!
Old Aug 18, 2009 | 10:41 PM
You will need the opti harness on the 96, but really nothing else. There will be a couple of extra things on the 96 engine that the 94 harness won't have plugs for (crank sensor and EVAP switch), but it won't matter. The OBDI computer won't be looking for them. Swap your 94 coil on, so that the harness connector will mate up.
Old Aug 18, 2009 | 10:55 PM
If you are running the 94 PCM, you have to use a low resistance (~4,000 ohm) 93-95 knock sensor. The 96/97 knock sensor, used with the OBD-II PCM's is ~100,000 ohms and will not work correctly. Alternatively, you can have the 94 PCM modified internally to work with the high resistance knock sensor.
Old Aug 18, 2009 | 11:13 PM
Please don't double post the same question.
Merging duplicate threads......
Old Aug 19, 2009 | 12:30 AM
LS1_03's Avatar
Sorry, posted this thread from my phone. I apologize.
Thank you for the responses!
Old Aug 19, 2009 | 07:15 AM
Oh, yeah, the knock sensor. I knew I was forgetting something.
DirtyDaveW
Dec 1, 2016 05:37 PM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
