swapped O2's, now car won't start
Old Aug 12, 2009 | 02:57 AM
AdsoYo's Avatar
I just swapped both my O2's from one side to the other to troubleshoot a different problem. When I went to fire it up, it wouldn't start. It was like trying to start it without the clutch pushed in, nothing happens (yes I was pushing in the clutch). Does anyone have any idea what could've happened?
Old Aug 12, 2009 | 05:19 AM
Guest47904's Avatar
Guest
You may have inadvertently pinched one of the brown wires going to the O2s which is powered by the 10 amp fuse #11 under hood. This fuse also supplies voltage to the ignition coil. Check the fuse.
Old Aug 12, 2009 | 05:25 AM
AdsoYo's Avatar
Fuse is good. I can hear the starter solenoid click when I try to start it. At least I think that's what I'm hearing. Everything has power. I measured 12.5 volts at the starter with key out of ignition. Maybe clutch switch? I'll unplug it and jumper the connection then try to start it I suppose. That will be for the morning, very tired.
Old Aug 12, 2009 | 09:17 AM
RUDEDOG's Avatar
In your first post you say nothing happens and in your second post you say the solenoid clicks. Which is it?
Old Aug 12, 2009 | 12:53 PM
AdsoYo's Avatar
Solenoid clicks, also VATS is removed. I stuck some wire I had lying around in the end of the clutch switch wire and tried to start it, didn't change anything.
Old Aug 12, 2009 | 07:40 PM
AdsoYo's Avatar
The starter signal wire was loose, all fixed
Britbilly
Jan 7, 2015 08:49 PM
Ricardo
Nov 29, 2014 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
