suspension?
What exactly do all these suspension mods do?? Like what kind of torque arm should I get and what does it do?? Also where is a good place to buy it from? Also i'm not control arms where can i get some good ones adn what exactly will it help?? I'm not looking for lowering springs b/c with my lt's my car will be too low. what are qa1's?? and what would they do and where can you buy them at?? I'm wondering about all of this b/c i have no clue about suspension and i'll never find out if I don't ask and i'm looking to sneak up on some ppl when i run them in the 1/4mile
If you are wanting to hook up, tires are the most important piece of the puzzle.
As far as suspension goes, the first things most people do are add subframe connectors, lower control arms, and lca relocation brackets.
The subframe connectors will stiffen the car up tremendously, especially if your car has t-tops. The lower control arms will help plant the rear tires to the ground. The relocation brackets for the lca's will help reset the angle of the control arm if your car is lowered, but they will also help a non-lowered car out as well.
Aftermarket tourqe arms are adjustable so you can adjust your pinion angle to help the car hook better. They are also stronger then stock ones that are just a stamped piece of metal.
QA1's are a brand of adjustable shocks. You can adjust them from everything from drag racing, street driving, or road racing.
BMR and Spohn are some of the more popular brands of suspension products. Good places to look are www.ls1speed.com or www.thunderracing.com .
I just kinda went over everything real fast, do a search on here to learn more.
RUENUF
Mar 13, 2016 03:37 PM
