Surging throttle-Not under load
I have been trying to get my car thru emissions testing for months with no luck. The car passes at idle, but fails at 2500(HC and CO both high.) One of the problems I'm having is holding the the RPM's at 2500. When I get the RPM's to 2500 it will stay there for only about 5 seconds and then drop about 500 RPM's and then it will work it's way back up to 2500 and begin the process all over again. The tester says I'll never be able to pass if the RPM's don't stay steady. One thing I have noticed is it doesn't happen when I first start the car(closed loop I suppose?) I have replaced fuel injectors, presssure regulator, fuel pump, sparkplugs and wires, and MAF. I"m running out of options and was wondering if anyone has any ideas before I take it to the shop?
