Surging throttle-Not under load
Old Jun 4, 2007 | 04:57 PM
skibum's Avatar
I have been trying to get my car thru emissions testing for months with no luck. The car passes at idle, but fails at 2500(HC and CO both high.) One of the problems I'm having is holding the the RPM's at 2500. When I get the RPM's to 2500 it will stay there for only about 5 seconds and then drop about 500 RPM's and then it will work it's way back up to 2500 and begin the process all over again. The tester says I'll never be able to pass if the RPM's don't stay steady. One thing I have noticed is it doesn't happen when I first start the car(closed loop I suppose?) I have replaced fuel injectors, presssure regulator, fuel pump, sparkplugs and wires, and MAF. I"m running out of options and was wondering if anyone has any ideas before I take it to the shop?
Old Jun 4, 2007 | 05:18 PM
transAMdriv3r's Avatar
Is there a check engine light or anything ? Im thinking it may be a bad Iac motor or dirty mass air flow.
Old Jun 4, 2007 | 06:07 PM
skibum's Avatar
No check engine lights and the MAF has been cleaned.
Old Jun 4, 2007 | 10:03 PM
skibum's Avatar
Would the IAC valve affect the RPM's at 2500 or only at idle?
Old Jun 10, 2007 | 06:23 PM
skibum's Avatar
Unplugged IAC and started engine. Idle RPM went to about 2000. Ran the throttle up to 2500 RPM and did not have any surging. Can I assume that the IAC is the problem?
Old Jun 10, 2007 | 06:40 PM
GMRL's Avatar
Thats kinda weird that it would idle that high with the IAC unplugged. Have you checked for possible vacuum leaks?
Old Jun 10, 2007 | 06:56 PM
skibum's Avatar
I have only done a visual check and made sure that all the connections were good!
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
karpetcm
Aug 14, 2015 03:02 PM
